justinm001
- Dec 18, 2022
- 1,537
this is on an RV roof. I currently have 2 parallel groups of 5 panels in series and am adding an additional 6 panel group. All are the exact same Renogy 100w panel with info below. All plug into a Victron 150/100 MPPT. Does it matter that one group will have a potentially higher voltage than the rest? Also since the roof is pitched a bit, 1 group is on the rear drivers side, other group is on rear passengers side and the new group will be half and half on the front. Not sure if this affects anything but the RV moves around so sun could be hitting different groups at different times.
I've never got near 1000w yet on these panels and most is around 550w. I plan on putting a total of 1800-2000w even though the MPPT is only rated for 1450w.
Max Power at STC | 100 Watts |
Open Circuit Voltage | 24.3 V |
Short Circuit Current | 5.21 A |
Optimum Operating Voltage | 20.4 V |
Optimum Operating Current | 4.91 A |
Cell Efficiency | 22.00% |
Operating Temperature | -40°F to 176°F(-40℃ to +80℃) |
Dimensions | 41.8 x 20.9 x 1.4 in (1062 x 530 x 35 mm) |
