Scoob-SanDiego
Using 4x 12V 100Ah LiTime LifePo4 batteries to build a 2S2P 24v batteries I am now looking for something to monitor
that the batteries are string nicely balanced.
I got a pack of cheap volt meters:
https://www.amazon.com/Battery-Indicator-Voltage-Capacity-Lithium/dp/B09JSJDY8N/
But it turns out that they are only precise to decimal point and even at that level they are not very precise...
I was thinking of using a CellMeter 8 for the task.
It is clearly designed to work with CELLS so typically < 4v per cell but I could not find any documentation where they specify
any maximum input voltage.... i.e. each one of MY cells would be a 12V lifePo4 battery.
https://www.amazon.com/gp/product/B073W4MDHC
Does anybody have experience with the CellMeter 8 and knows if it will take the 12V cell input?
And if not the CellMeter 8, do you have any suggestion for a cheap always-on volt meter cell I could use to monitor the state of balance of my 2s2p battery?
Either cheap (but accurate) voltmeters OR something like the CellMeter 8 which monitors all cells and even shows you the maximum delta drift between the highest and the lowest cell?
Thanks!
- Christian
Thanks!
- Christian
