Scoob-SanDiego
BACKGROUND:
I have 4x LiTime 12V 100AH batteries and my MPP inserter runs at 24V.
It looks like most setups configure things in 2S2P (two strings of 2x12v inseries) and the two strings connected in parallel.
Recently I have been learning about the problems that unbalanced 12v batteries in series can cause with an inverter and the capacity of your battery bank.
Ian at watts247.com has some GREAT videos on the subject explaining the benefits of using a battery equalizer for your 12v batteries (NOT active balancer).
watts247 carries two 12 batteries equalizers:
A 2x12v batteries model: https://watts247.com/product/eq-24-2-24v-battery-balancer-balances-2-x-12v-batteries-in-series/
And a 4x12V batteries one: https://watts247.com/product/eq-48-...-batteries-or-any-x-3-2v-batteries-in-series/
The videos explaining what those devices do and why they are useful / needed are very good:
https://www.aliexpress.us/item/3256805739573881.html
Naturally you can save a few bucks by buying from China but if you have questions, need support or warranty, a knowledgeable US based vendor has its advantages
QUESTION:
Is there ANY advantage in running my batteries in 2S2P. vs in 2P2S
i.e. two stinrgs of 2x12V then put in parallel to get 24V 200Ah
vs 2 x 12V batteries in parallel (creating a 12V/200Ah battery). THEN put in series to create a 24V 200AH battery.
In the context of using a battery equalizer, the two 12V batteries in parallel are already self equalizing between themselves.
You can then use the smaller/cheaper battery equalizer (the one for 2 batteries instead of 4) to balance between the two 12v/200Ah batteries.
So my question again: Other than using a cheaper equalizer, is there any benefit of 2s2p over 2p2s?
Thanks!
- Christian
QUESTION:
Thanks!
- Christian
