Moseworth 12 volt 100ah LiFePo4 batteries
Grampa
Alberta< Canada
I started with 3 of the Moseworth 12v 100ah batteries this spring and tested them before installing in my RV.
All 3 tested slightly over 101ah which I was pleased to see and found the performance this summer to be very good.
Just bought the same battery and tested it (after fully charging it, letting it rest and then load testing) but it only tests to 95.9 ah
Is there a concern long term that the slightly under capacity one will pack it in early?
It could be sorely out of balance. If you want to baby it to return it to balance, you could get some capacity back. Or why not just exchange it for a new one?
