samuelprsns
- Dec 5, 2022
- 4
Hello,
I've been having an issue with my MPP PIP-LV2424-MSD Inverter. I have a single 24v 202AH BigBattery HAWK MAX LiFePo4 Battery, 4x200w solar panels, and no grid access at all. It is now an every night occurrence that when I stay there I am going to bed with the battery between 26.4-26.8v, then using just a mattress pad heater that is about 80w, plus an exhaust fan that is 35w, and a heating pad on the battery that is 20w. And when I wake up, power is gone.
That would be fine if the issue was just that I don't have the power to last the night and need an additional battery, but what's really annoying me is that when the sun comes up and I get down under the cabin to check on everything, the battery has clearly been charging up in the sun, and has sometimes returned to as high as 25.5 or more volts, yet there is no AC power coming out. Not from the battery, not from the sun. This is solved by me simply switching the inverter off and then back on. When I turn it back on, all of a sudden it begins feeding AC power again as if everything is fine.
Why on Earth is the lv2424 not feeding power even if the sun is blazing, the battery has enough power, and it is switched on. How do I keep myself from having to just reboot the machine every morning.
It's also especially annoying because it's not just me staying there, I put up friends and also airbnb it, and those people don't know how to go reset the inverter. Plus the only access to it requires going outdoors, and it's cold! I just want for people to be able to continue to charge their phones and maybe run an electric kettle! The sun is up! The battery has power! wtf! Thank you.
Here are my settings:
01- sbu
02- 40A
03- APL
04- nor
05- USE
06- Lrd
07 - trD
08- 120v
09- 60hz
11- 30A
12- 24.0v
13- 28.5v
16- Snu
25- fdS
26- 28.7
27- 28.2
28- Sig
29- 21.6
01- sbu
02- 40A
03- APL
04- nor
05- USE
06- Lrd
07 - trD
08- 120v
09- 60hz
11- 30A
12- 24.0v
13- 28.5v
16- Snu
25- fdS
26- 28.7
27- 28.2
28- Sig
29- 21.6
