TheGriz
More Power Scottie!!!
- Feb 17, 2020
- 128
Hi Folks,
My "portable" Solar system is in final assembly. Just need one more very critical component...the Solar Charge Controller. The options are many, and my experience is very limited. So, I am asking for recommendations.
A few details first. The battery pack is the Xuba 280 12V LFP pack with the Chargery BMS8T. The Inverter is the Edecoa 3500/7000, however I only plan on using maybe 2500 watts of it (purposely overbought because of a near disaster prior experience with cheap POS inverter). Lastly will be using up to four 100 watt solar panels for total 400 watts.
I am budget minded, but don't want to be dollar foolish. So I am not looking for the bells and whistles, unless needed. I did some research and and am leaning toward EPever's 30 amp MPPT controller for $95:
Thoughts??? Anything less expensive that will do the job? Is this a quality SCC? Am I buying the right size at 30 amps? Should I go with a Renogy equivalent? All feedback appreciated.
Regards,
Mike
Regards,
Mike
