chadat23
When using an MT50 to set up an Epever charge controller, when you set it to use a Li profile it defaults to using a low temp cuttoff, but seemingly when you use the User profile it doesn't and will charge at too low of a temp. That said, my BMS has low temp stuff so the cells should be safe, but when the bms turns off charging, that seems like it'd be the functional equivalent of disconnecting the charge controller which seems to be bad for the charge controller (and could maybe create voltage spikes that could be bad for other things on the system?). Is this something I need to be worried about?
