Firstascent
- Mar 7, 2020
- 265
I’ve got a big issue, I was so excited to finally do the final AC connections only to find out that my wires just pull right out, and easily too, there is little resistance and it can slide out.
I hate these spring terminals, give is screw clamps!
Anyways, have you guys seen or heard of it this bad before? Open to any advice/suggestions/comments.
Multiplus-II 2x120 model
I know there are mixed feelings on using stranded wire. I used 6/4 stranded wire with ferrules.
I stripped the wire per the Victron manual
I used ferrules of the correct length per the Victron manual
I used a 2.5mm flat blade screwdriver inserted correctly into the terminal correctly to aid in wire insertion. (Yes the correct top hole, not the one the wire goes in)
I used high quality UL listed ferrules and quality crimping tools.
I took a short vid but I can’t upload vids here. The photo is just a screen grab from the video of me very easily pulling the wire out as if it weren’t clamped down at all.
I’m pretty picky on my work, and I followed the manual as well, but I’m human. These are pretty straightforward though so not sure of anything I could’ve done wrong.
Always good to get an extra set of eyes and info, so here I am asking![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
