The batteries were stored in the basement, which is heated. So they never got below 60 degrees and never over 70 degrees. I'd periodically checked their voltage and it was where the manual said it should be for storage. Both batteries were always with .01 volts of each other.
Below is the link to batteries
I'm using a Noco Genius10 charger that has a lithium charging mode. When I connect the battery, the lithium light comes on and after about 5 second it starts blinking. Which the charger manual says it means that the charger is slowly pulsing on and off because the charger senses the battery is charged less than 25%. I've left it in this mode for a a few hours, then removed the charger and tested the battery voltage to be 7.25V. Then I'll come back hours later (without the charger on it) and retest the battery voltage and it measures 2.84V.
I sent an email to LiTime about the issue and this was their reply.
"Thank you contacting LiTime service, it's Ricket, i am pleased to help.
Since the battery has been under voltage, do you try to connect the charger with the activation functions to activate this battery ?
If you don't have the charger with activation function, then the 18-36V solar panel connect with this battery for 10-30s without the controller in a sunny day also workable."
Unfortunately, I don't have solar panels, nor do I have a power supply. All I've got is the NOCO Genius 10 charger.
