Bossrox
Solar tinkerer
Got my new 8s done & charging. 1st thing I see right off the bat is the cells are charging near equally compared to my 1st 8s that's totally a mess 'cuz I got stuck with grade b or c cells but it delivers the full capacity anyways. So now I have 680 a/hrs available on my 24v inverter or about 16 kw. I have the bms hot wired bypasing the protection which still gives me cell monitoring ability so I'll be adjusting the current/volts manually as needed & I'm topping it off in series this time rather than a parallel string to see how that works out. Here it is much the same build as my 1st.
