Lancelot1954
- Jun 24, 2020
- 7
I purchased the following Solar Panel system without batteries a number of years ago and am ready to get the batteries for this system. I am a total novice and would like advice on how much battery power would best match this system and the type of batteries. Also curious what other items I would need to be able to appropriately use this system without hurting the batteries by decharging them to much or any other monitor I should get.
8 - Kyocera 315 watt solar panel w/ MC4 cables. Vmp 39.8 VDC, Voc 49.2 VDC,Isc 8.5 A DC, Imp 7.92 A DC
Single 18' length XRS rail (17lb)
Kit, Mid Clamp F-G 2.50", Mill (4 pcs.)
Kit, End Clamp F 1.81", Mill (4 pcs.)
Kit, Adjustable L-Foot, Mill (4 pcs.)
XRS Splice Kit (one internal splice)
MC4 Solarline 2 (latching) extender cable # 10 AWG 15' Male/Female
MidNite Solar MNPV6 Array Combiner 6 Circuit
PV Array Breaker, 15 Amp 150 VDC DIN rail mount for Midnite or Outback Combiners.
Outback Power MPPT Charge Controller 80 amp 12-60VDC 150 VOC max. input 12v-1250 watts 24v-2500 watts 48v-5000 watts 60v-7500 watts 16.25" x 5.75" x 4”
E-Panel Gray steel chassis with 250 amp 125 VDC inverter breaker for Magnum Energy MS-4024AE
4000 watt 24 volt inverter/105 AMP PFC Charger/120V/240V Input/Output
Digital LCD Display Remote Panel w/50 ft cable
