Bfrenchsea
Hello,
My first question is regarding the proper installation for a Victron Smart Shunt given what I would like to monitor. In short, I want to monitor a new LifeP04 battery bank regardless if loads are DC or AC through my inverter. I‘m still trying to fully understand if the smart shunt will monitor *everything* in and out. We have a week-end, off grid cabin in the central Cascade Mountains in western Washington.
My current system:
1,000w solar array (4 panels on roof) Solar World 255 Watt solar Panels
Outback FlexMax I-amp charge controller
Midnight solar e-panel (MidNite Solar E-panel MNE250STM-L Gray steel with 500 A Shunt, 250a breaker & 1-20 amp AC Din Rail Breaker for MS4024/ MS2812/MS2012) (NOTE: when this was originally installed I had a Magnum Inverter/Charger)
Outback VFXR 2812 Inverter Charger
Mate3S
Trimetric 2020
Honda EU 2200i generator
8 6v Trojan L-16s wired in parallel and series for a 12v system.
We run all our (led) lights, water pump, and starlink/network from a DC breaker box. We use the inverter for charging devices (phones, tablets, computers, etc.) and other random AC needs. When we first built the system 15+ years ago, 12v DC was a perfect, simple system for us. I’m working on slowly upgrading the system and my current project is changing our batteries to Li Time LifeP04 batteries. We will remove the FLA and install the new batteries that just arrived this week. I know I need to reconfigure the charge controller and inverter/charge. At the same time, I’d like to install the Victron smart charge that I bought so that I can accurately monitor the new batteries. With the current setup I can monitor the batteries with the Trimetric (while onsite) and OpticsRE while away. Although, I don’t think it monitors just the DC load when the inverter is not turned on. So my question is, I think, 3-part:
1. Will one smart shunt monitor the *whole* system (in/out, DC/AC)?
2. Do I need two shunts - one for DC and one for AC?
3. Can I replace the current shunt that is in the e-panel with the Victron shunt?
4. How should I wire all of this depending on answers to 1-3?
The next phase of the project will be to install the Cerbo GX and screen. I then want to add more solar panels (different location so that means another charge controller?) and probably upgrade the system to 48v, requiring a decision on a new inverter/charger.
Thanks for any help or guidance on my questions and open to thoughts on my plan for the future. Thanks!
My current system:
Mate3S
Trimetric 2020
