Ok. I am frustrated.
Purchased this controller for our 192 watt 3 panel system to power our well pump.
It will NOT charge the batteries. I've completely disconnected and reinstalled this 5 times already. I'm at my witts end.
It shows the panels are putting out 22v. The batteries are at 22.7 volts. Our load is working in 117 automatic mode. The batteries are showing only 1/4 to half charge per the display on the CC. There is an arrow between the batteries and the load, but none between the panels and the battery.
I cannot get to any controls in the battery selection aside from picking the battery type. The it shows me a 20.0v indication. and won't allow me to modify that.
I am assuming that means that when the batteries reach 20.0v the panels will begin to charge the batteries?
That is actually the lowest amount of input that will allow our solar pump to run. But I would prefer to have the batteries begin charging at a higher voltage, like 22.0v
First question is am I wrong about when the panels will begin to charge (communicate) with the batteries?
Secondly, how on earth can I change that if that is the case?
I did take pics, but my camera stinks and the sun was too bright so there is a lot of glare on the display.
Any help would be greatly appreciated.
