dashboy979
- Nov 8, 2019
- 7
Recently came into possession of three Uni-solar 136 watt panels and a Midnight Solar Kid charge controller. The controller is rated at 150 volts/30 amps.
Hoping for recommendations on what circuit breakers to use for the pv panels. The previous owner of the panels replaced the pv wires with new 8 gauge wire. I tested the panels with a meter and they were pushing 43.2 volts so they seem to be in good shape despite being 7 years old.
My hope is to use this system to power a small frigerator freezer combo with a 3000 watt inverter. The frg is a combo 12 or 24 volt DC/ 110 volt AC type (run on 12 volt battery or plug into AC outlet) and pulls 70 watts total input power with 5.8 amps.
The panels are 136 watts, (33 vmp), (4.1 imp), (5.1 isc), and (46.2 voc). I currently have a 200AH lithium Iron phosphate battery, but will be acquiring a second one in a couple weeks.
Just can't figure out what b size breakers go between charge controller and the panels. I plan on using a 30 amp breaker between the charge controller and battery, but a little unsure about that as well.
Any help is much appreciated.
