Hi! I'm doing a camper van conversion and I want to double check that the main components I have will work ok together and that I will not have any issues if wired correctly with the right fuses, circuit breakers, etc. I might add more solar panels in the future, but right now I'm starting off with 2, 100 watt panels. Here's a list of what I have....
2 - 100 watt solar panels
Renogy 12V 50A DC-DC on board battery charger with MPPT
2- 125 AGM 12V Vmaxtanks
Renogy 2000 wt inverter
I know I will have to figure out the fuses, circuit breakers, etc. If you like to advise on these as well or anything else I should know, I'm all ears.
Much thanks!
Carey
Much thanks!
Carey
