I am replacing my old 12v Lead acid system with 24v lithium and new MPP LV2424 inverter/cc, but need to keep one of my 12v Lead acid battery to start my generator and/or run a couple 12v items (10 amp pump, etc). Generator draws less than 10A to crank and has its own 10A fuse. I was looking at Will's "2000W 24v off grid" How to, and he recommends the 24 to 12v 40amp converter step down (below). My questions: Do I need a 40a for my limited loads? Cant I use lets say a less expensive 20A? ...This is just to keep the starter battery topped off and occasional 60 seconds of water pumping, is this appropriate to "float charge" my battery? I still have my old pwm controller, so cant i just feed 24v dc into the PWM charge controller and have it provide 12v float charge to my Lead Acid gen set starter battery? Im even considering just putting a small 30w panel on the roof near my new array to provide energy to the old pwm and maintain a completely separate self sustaining 12v system, just to start the generator & pump. Any ideas?
(https://www.amazon.com/dp/B01LYK6G2...a6ade415085fbe081d9edcd496d45b&language=en_US)
