Hello everyone and thanks in advance!
I have previously mentioned that I am building a 20 AH LiFePo4 battery generator as a sort of prototype for the real thing. I am about 85% finished and have a battery monitor attached, but when I power the device up, the battery meter reads all 8's. Every single LCD on the display is activated. This leaves me with no useable data.
The literature is not helpful, even worse than vague. The literature states that the exact condition I described indicates a full battery, but this is confusing as I can't even get a voltage reading. The literature even contains a picture of the monitor in this exact condition, but I can't seem to figure out a way to get it out of that condition so I can get useable information.
Is this a normal condition for a battery meter? Is there some setting I am missing? Do I have a faulty meter? I am about at wit's end and I would just replace the meter were it not for the fact that the literature seems to say that this is normal for a full battery. I have even gone so far as to put the device under a load and very carefully watch the voltage to see if the battery meter seemed to pick up on any change, but nothing had happened. As it stands right now, the battery sits at about 70% state of charge, based on voltage (and after having been charged by removing the battery and charging with a separate, dedicated Lithium charger).
This is a shunt-type device and I have hooked it up correctly as per directions.
So after all of that, my basic questions are:
1) Is this normal for a battery monitor?
2) Is there something I need to do to get meaningful data?
3) Does this indicate a faulty battery meter?
I can provide pictures if that would be helpful.
Thank you very much!
SIsolar
SIsolar
