Robbert
Hi all,
I have not posted much on the forum, but have been reading a lot, learning a lot and now have decided to build a new Lifepo4 battery as a replacement for an AGM battery bank. Most of the parts are on their way, but expect everything to be here by the end of March. Since I live on the Caribbean, it does take some time to have everything here.
During the build I will share pictures and plans and hope that you provide me with feedback, so this project could be completed successfully.
Current setup:
2 x MPP Solar pip7248 max (not in parallel)
2 x AGM bank (8x Full River DC 400-6 per bank)
20x 415 Watt panels (10 panels per inverter).
In the new setup I will parallel the AGM banks to one inverter so the capacity of that bank is double the size. Since these battery degenerate pretty fast, I hope this new bank could be used for another 2 years until it has to be replaced.
The new battery will be a 280 lifepo4 bank connected to a single inverter.
For this battery I have ordered:
17 REPT 280 cells (one additional in case there is a bad cell and shipping takes ages here)
JK-BMS (with RS485 CAN module so it could connect to Solar Assistant)
A pre-charge button with resistor will be added, as well as a Class T-Fuse.
Everything will be in one enclosed shelf so it is possible to hook it directly to the inverter and the current installed breaker).
The build will go slowly but hoping to make some progress every week after parts are dripping in.
Attached the 'design' of the setup and the first pictures of the build.
Hope you can give me feedback and guidance along the way.
Current setup:
