Vonzacsavbal
Going to have 5 Li Time 100 ah 12 v batteries. I want it portable and putting wheels on igloo cooler. I already had a 12v 3000w inverter, so I'm going to keep my batteries 12v. Parallel. I was going to use a + and - bus bars to attach each battery to. 6 lug. So 5 batteries to the lugs, and then the 6th lug to the inverter. I am usually just going to use ac charger, 60 amp, to charge the batteries individually at first. Then after they are fully charged to same level, I was wondering if I can just connect to the bus bars and charge all 5 batteries together with the AC 60amp charger. Now we're talking 500 amps here, should the bus bars be able to handle 150? 250? 300? or 600 amps? Also should I use 1/0 or 2/0 cable from batteries to the bus bars? I also have a solar charge controller that I will eventually hook up later to 3 100 watt panels. I figure the 5 batteries will give me at least a few days running lights, and maybe a small portable heater if needed. Any help would be appreciated. I am new to all this, but want piece of mind if my power ever goes out for a long time. Or my extended family, hence to keep it portable and throw in my truck if need be.![Solar cooler.jpeg Solar cooler.jpeg](https://diysolarforum.com/data/attachments/163/163410-707219f4a89148de4d0e633c2c816a9b.jpg)
