Hello everyone, i'm working on my first solar project. Normally i'm try-and-error learning guy but I can't give much of room for error when it's safety issue so I'll appreciate your help.
My Goal is going off-grid without modifying existing current system as much as possible since it's testing phase for me.
Questions.
1. In my knowledge, there should be 2 hot wires and 1 neutral for Main. I see 2 hot wires on "2" but where is natural wire? this electrical panel was not usual than normal.
2. If I turn off Main ("2") to cut off electricity from the grid, and remove the AC wires ("1"), then connect 2 wires to where AC wires were, would it technically off-grid and work?
3. Why "1", the AC breaker has one black and one white wire? aren't they both supposed to be black/red representing hot?
4. If I want to keep AC, and and doesn't need electricity for "3", just like question 2, remove "3" wires and connect inverter there with 100 amp breaker, would it also work as off-grid?
I apologies for my language, still not used to electrician vocabularies .
Oh yes, and when I connect from inverter to the panel, I'll connect the ground and neutral wires to the same panel too.
Questions.
