sunshine_eggo
Happy Breffast!
That's good to know. I can set up my relay network to only pass L1 in that situation. For the dynamic nature of on RV, is there a benefit to "switch as a group"? I'm guessing this setting off would be a safe fall back for three phase power (208v).
Switch as group disabled is the ONLY way you can charge a 120/240VAC split phase configuration with only 120V on one inverter. If switch as group is enabled, it will only charge if supplied with split phase power.
Is setting up dual inverter possible to do through the Cerbo GX, or do you need the USB dongle?
Parallel configuration of inverters requires a MK3-USB adapter and VictronConnect or VEConfigure3 for the initial programming.
