Hi all!
It seems that all-in-one inverters (like this Growatt inverter) are becoming more popular nowadays and have a ton of pros over the modular off-grid system that one would be using for an off-grid van or RV system, at least according to Will Prowse. As I'm seeing it, the only big drawdown is the idle power consumption that tends to be relatively high and can drain out the batteries. According to Will's page that shouldn't be a problem if you don't need to have the inverter ON 24/7 (which I'm not intending to do). My only question is, do these AIO inverters have a dedicated switch to turn off the inverter only and still run other part of the system (solar charger especially)? If not, Is it possible to easily install a switch myself for that purpose?
Thanks in advance!
Thanks in advance!
