Hi all,
Brand new to the solar game. Here’s my setup:
1x50 watt solar panel into a small 10amp PWM controller fed to my vehicle 12v battery.
1x90 watt solar panel into a 10amp mppt controller fed to the same vehicle 12v battery.
I was attempting to hook up this power meter I got on Amazon just to monitor the power being produced by the panel.
90 watt solar into the source on the meter and load into the MPPT controller.
The power meter does not turn on nor does it pass thru the power from solar thru the meter to the controller.
Am I doing something wrong or do I have a defective meter?
By the way, with the 90 watt panel directly into the mppt is generating power as I have a Bluetooth app that connects to the MPPT. It was generating over 12v which is what that meter needs to run.
Am I flawed in thinking a solar panel should power that power meter on the source side?
