Hopefully this helps some people I saw a lot of people questioning whether this was a 16s or 15s battery since it's labeled as 48 volts all around. It does appear to use Grade B or used cells so I would probably spend the extra $300 on a known brand that uses new cells but here are the pictures
![1000030279.jpg 1000030279.jpg](https://diysolarforum.com/data/attachments/229/229607-b19c8e1aef707f75526241e0fed190ae.jpg)
Pretty standard Chinese OEM design that we see on a lot of these
![1000030287.jpg 1000030287.jpg](https://diysolarforum.com/data/attachments/229/229608-57c99d9f156a3d52ca09f67145b5d7c9.jpg)
Good news, it is at least a 16s, used cells or not that's better than a 15s.
![1000030285.jpg 1000030285.jpg](https://diysolarforum.com/data/attachments/229/229609-f39d9cdfe7c9c5051d6eb011a743fb86.jpg)
Forgive me I'm quite new to server rack batteries so I'm not familiar with this BMS but here it is
![1000030283.jpg 1000030283.jpg](https://diysolarforum.com/data/attachments/229/229610-e4929850c36b74d3b0f952fe7e1ac265.jpg)
And finally here's a picture of the cells which look like textbook used cells complete with scratched off QR codes and voltage testing labels. They all appear to be within .005 according to the labels at least. I will update this post with a capacity test below once I get around to it. It's going to take me a while because my capacity tester is only 5 amps at 48 volts. I really hope this helps someone, I'm not going to put a link but you can find it on Amazon I'm sure
personally I wouldn't buy it again but I'm not going to go through the hassle of returning it as long as it capacity tests fine.
