STC is a nice set of fixed conditions but how many reach those levels in real life? Inverter limits state Watts and Amps but not if they are STC, NMOT, or NOCT values. The newer M10, 44" wide, panels exceed the EG4-18 MBBT 25a limit and the S-A 15 26a dual string limit if the STC value. The newer N type topcon panels have higher Isc amps
but the usual lower NMOT numbers.
SignatureJames says the EG4 is good for up to 1.2 x 25a=30a. Sol-Ark says the -15 self limits above 26a. Older comments suggest STC provides a safety reserve but does the Canadian Solar really need 24% safety greater STC than NMOT for safety. Watt reduction is 32%., maybe that string can be a few panels longer
Has anyone measured coming close to STC values in real life? Why have NMOT and NOCT values other than setting realistic expectations.
