robertsig
Greetings all. I'm about to dip my toe into the world of solar and am very much a noob. I need some advice. I may or may not do-it-myself depending on how daunting I find it all.
Here in Cleveland we once in a while get power outages. When that happens, my primary concern is the fridge, followed by heat (if it's the Winter). I bought a Honda EU2200i generator and installed a 30A inlet to my electric panel for when I need to power the basics. All this is manual - nothing automatic.
I thought about installing permanent solar panels on part of my roof to handle my fridge during outages. I have a Sense monitor in my panel which says the spikes are less than 900W and running watts less than 150W. Total kWh per day is 1.6kWh. I'm sure this is a noob question, but what I picture in my mind is simply a 120V outlet available to me for fridge use, that ties into the panels, batteries and inverter. More manual interaction.
And then I thought, what a waste to have that power sitting their idle every day unused.
And then I thought, what if I sized this system so it could run my fridge 24/7 even if I have grid power? Then I wouldn't need to worry about the fridge during outages.
And then I thought, but if the system failed, or I had snow on the panels, I'd lose my fridge, so some automatic failover mechanism (whichever direction I decide) might be worthwhile.
Since a fridge doesn't technically run continuously, I assume there is a solar installation capable of handling the ups and downs from batteries while providing sufficient power throughout the day? How about at night? I'm okay with power cutting to the fridge for up to 2 hours since it'll stay cold, but would want it to continue after that.
So as you can see I'm all over the place. I want to handle small (or even longer) outages where I can protect my food, or perhaps even a bit more. I have no problem pulling out my generator in the summer, but it's not fun in the winter. Ideally I would avoid mechanisms that tie into my electric panel and ATS, unless that is my only option. I sort of like the idea that this would be autonomous, up to a point. ie. Treat it as emergency power unless it can meet my daily fridge needs. The other side benefit is I don't need to investigate bigger generators, which I've been doing. This little 2200W Honda can take care of my other necessities if the fridge is out of the picture.
I welcome some basic product or complete system recommendations, along with expected prices. Maybe it's not worth it? Maybe I could simply live with my generator? I don't know just yet. As many here are aware, there are other semi-tangible benefits to not relying upon grid power or gasoline during certain scenarios. At least we don't get the hurricanes!
