rogerball0
- Feb 18, 2021
- 21
I hope someone can help. I originally thought i had a duff cell in my pack, (280Ah battery using a Daly 4S 150A BMS). The blue tooth app shows three of the cells at 3.47 V give or take 0.002v but cell1 is reading 3.265v (0.2v differential).
I immediately opened the battery box and put the multi meter across each cell and they all record 3.47 V, I even unplugged the five pin balance lead plug that plugs into the BMS and put the meter on each pin of the plug as per Daly's instructions when setting up the BMS and again got the same (3.47v) across all 4 cells so i know the balance leads are good.
Why would the BMS give such a different number on the app, is there a way to reset the BMS back to factory settings and see if that works? Have tried different cells on the same BMS and get the same problem so i know the cells are good and think its the BMS.
Is there a chance the cell with the duff reading could get damaged by overcharging?
Any help greatly appreciated
Roger (UK)
Roger (UK)
