My BMS voltage readings and my multi meter readings are different
Aussie
Qld. Australia
When I look at my cell voltages on my phone app they are different then my multi meter readings. My multi meter showed most cells within 0.005 of each other but the app shows different voltages for the cells. As much as 0.031. checked my connections , all good. Any ideas why and is this going to be a problem. It is a new build, it has just got top balanced. My concern is that if the BMS readings are wrong it won't function properly. So is the BMS "broken"? Any ideas?
With the overkill solar app, you can calibrate the voltages by entering an actual voltage for each cell.
I attempted to do this. I got on the calibrate screen, entered the correct voltage, pushed "write" and nothing happens. Do the cells have to be at rest when this is done? Mine were discharging at the time I attempted to rewrite the voltages. I tried several cells.
Do you have the Overkill manual?
Appendix B tells how to calibrate.
Elsewhere, the manual says:
If you plan to calibrate your BMS, the voltmeter needs to be accurate to at least 1 millivolt. If you use a cheap or badly-calibrated voltmeter, you will only make your calibration worse.
I
I am checking at the cell terminal.
The Total voltage reading i.e. 53.0v is the same with the multimeter at the terminal as the BMS reading
I would try my best to ignore the differences unless a significant capacity issue shows up.
53.0 does not say much at the calibration accuracy level. Is it 53.000 and 53.000? almost need a fourth decimal to have good faith in the third.
Thank you. I have downloaded the manual. I shall see what it says and have a go.
I think I have got a significant variation. 0.080 v Or is that nothing to worry about?
I just can't imagine if the total voltage is correct that there are 80 mV of calibration errors between cells.
I am using the overkill app and when I go to calibrate no warning comes up . I can input figures, but when I push "Write" it does not change the existing figure. Any thoughts?
It appears that the Overkill manual was written for the Xiaoxiang app.
On the the Xiaoxiang app, a warning appears saying "Note: only use if you know what you are doing".
Maybe try using the Xiaoxiang app.
If that does not work, I would ask Overkill for support.
How do you access the calibration screen on the Xiaoxiang app ?
