Hi everyone, Peter here.
I have health problems and keep myself isolated from the covid world.
Last year I built a shed, 10 feet by 10 feet and 12 feet tall with a 45 degree roof. The shed has a south westerly side where I have placed 4 120 watt monocrystlline panels in series to give me a total of 480 watts. Next I have a 60 amp solar charge controller with x2 12 volt 50 Ah LifeP04 series batteries wired in series to give me a 24 volt system. I also have a 1500w DC 24v to AC 220v inverter with a fuse inline on the in power cable to the inverter. so now you know what I have and yes it was a kit from Eco-Worthy.
I started and found the batteries had minimal charge and at the end of the first day my charger displayed
Time 17:30 Oct 14th
Main menu 26.5v
Panel volts 27.1v
Panel Amps 0.53a
Batter Volts 26.5v
Discharge 0.00 I have not used my inverter yet
Charge Ah 19Ah
Discharge Ah 0.00
Temp 23c
Load 16 I don't think I need to use the load side of the charger for anything
Error E0
and its on Bulk charge
This was after a good 8 hours of sunlight on my panels with some cloud
Today at 13:30 Oct 15
Main menu 27.8
Panel volts 28.6v
Panel Amps 8.35a
Batter Volts 28.0v
Charge Ah 43Ah
Discharge Ah 0.00
Temp 30c
Load 16
Error E0
So my questions are many to understand better but first I need to explain I want some heat in my shed as I spend a lot of time in it. Yes I do have mains power but that cost money and I wanted solar to save me this cost.
1/. How long to charge my batts on a nice day and a cloudy day.
2/. How high will the voltage go as its a 24 volt system.
3/ Will the Ah hit 50 Ah when the batteries are charged.
4/. Do I need a batter monitor so I know the charge level better.
5/. How many watt can I expect to be able to use in 24 hours daily.
6/. I understand I need to fully charge batts at least once a month for better batt life, so do I ned to add more panel to speed up the charge rate.
7/. if yes the to 6/. do I need another charge controller or can this one handle another 4 panels.
8/. Should I also be thinking of getting more batteries for cloudy days to hold a charge longer.
Last year I heated my shed with candles and flower pots, not ideal and not warm enough but I managed and looking forward to a better year this year.
I wish you all well and good health and thank you for any help you can offer, Peter
Time 17:30 Oct 14th
Main menu 26.5v
Panel volts 27.1v
Panel Amps 0.53a
Batter Volts 26.5v
Charge Ah 19Ah
Discharge Ah 0.00
Temp 23c
Error E0
Main menu 27.8
Panel volts 28.6v
Panel Amps 8.35a
Batter Volts 28.0v
Charge Ah 43Ah
Discharge Ah 0.00
Temp 30c
Load 16
Error E0
