UltrasoundJelly
- Nov 16, 2021
- 42
Hey guys, I built a 100Ah 16S LFP battery with an Overkill BS and put it into service 26 months ago in my lawnmower. Top balanced. Tested capacity at start was 101aH using a battery tester a 2-3A load over 32 hours.
Stored in my shed at 50-90F all year round, taken out only to mow. BMS reports 26 cycles. I attempted keep SOC at 40-70% all year when not in use, but I suspect that my shunt has a parasitic load so at least once the SOC dropped to 0 for an unknown length of time (probably a week or two). I charge at 10-11Amps, only to full right before use.
I have just run a capacity test and I'm showing 96.6 Ah with the same load (5.4% loss). I noticed that right after full charge I have an cell max delta of 69mA, posting the BMS cell distribution here.
My questions: would you rebalance? If I do rebalance I'd like to keep the battery built and perhaps top off each cell. Is there a problem keeping the BMS attached and placing a 3.65v charge load to each individual cell?
