Hello solar diyers! This my fist post and I am very glad to join this forum!
Here is a situation that puzzles me for some time now.
A friend of mine has installed a net-metering solar system (with battery) in his house. Unfortunately, his grid connection is 1-phase and the max PV power allowed by our grid administrator is only 5kW. This covers only a small fraction of his electriccal consumption, as there are 4 or 5 freezers in the house, working 24/7!!! Even during summer, his system will hardly export any energy to the grid, as air conditining steps in as well.
The option of going 3-phase is out of the question both technically and finacially. So, the only possible solution I thought is to install a second, off-grid solar system, whose sole purpose will be to charge the battery of the on-grid system, while the on-grid inverter will be configured to export all its surplus output to the grid. This way, the grid-connected system will store some energy in the grid and use it along the energy of the battery (charged by the off-grid system) during the night in order to keep the house running. Is this technically possible? Can I have two inverters connected at the same time on the same battery or should I use some kind of switching device to switch the battery between the two inverters?
I'd appreciate any suggestion.
