mcsullinsberg
- Apr 26, 2022
- 2
Hi friends, first post here and a newbie on their way onto a shuttle bus conversion build. Hopefully I can manage to at least get some of this terminology correct. So I have purchased 4 - 320Watt Solar panels (https://www.ecodirect.com/Q-Cells-320-W-Mono-Solar-Panel-p/q-cells-q.peak-duo-blk-g5-320.htm) and I see that the open circuit voltage on the panels is 40.56V to total 162.24V. I was planning on purchasing the Growatt SPF 3000 all-in-one unit (https://signaturesolar.com/content/documents/GROWATT/1519008-specs.pdf) but in the datasheet for that unit, it says that the maximum PV array open circuit voltage is 145VDC. I know that these units will usually outperform their max specs, but that's not really something that I'm willing to put to the test. So my question is, would it be worth it to shoot for a larger all-in-one unit (I'd like to keep with that style vs. individual components) or should I just wire 2 of the panels in parallel and the other two in series? Thanks for any help you can offer!
