Hello ,
I'm encountering an issue with calculating the theoretical open-circuit voltage of my PV system. The formula I'm using results in discrepancies of over 5% specifically for low irradiance conditions (below 200 W/m²), where the calculated voltage is consistently lower than the measured one. Interestingly, for higher irradiance levels, the results are accurate.
The formula used :
Vtheo = m * Vostc * [1+Beta * (Tcell-25)] + Ncell * m * 8,62 * 10^-5 * (Tcell + 273) * ln(G/Gstc)
m : NO. of Modules
I've already checked the units and ensured that all parameters are correctly inputted.
Do you have any suggestions on how to address this problem? Are there additional considerations or factors I should take into account?
Thank you in advance for your assistance!
The formula used :
m : NO. of Modules
