Hiker
On my minivan I have two 100w panels, a Victron 75|15 MPPT controller, charging a 12v 100ah LFP battery. The system has worked great, last year I never needed shore power while running lights, fans, a TV, while charging phones, tablet, a laptop, an Ecoflow Delta Min and ebike batteries through the EF.
I saw the Orion on sale at nearly 1/2 off so I bought it. I'd like a little guidance from the group on how to wire it. I have just under 10' (one way) from starter battery to where I'll place the charger and another 3' to the leisure battery. What's the groups recommended AWG from the starter battery to the charger and from charger to the leisure battery? I'm thinking 8 or 10awg and 10 or 12awg. Will these be sufficient? What size fuses are recommended? Since my solar set up is portable I'll be running the wires from charger to fuse box with Anderson powerpole connectors. The charger will go under the front seat to the left. The charger will feed into the fusebox. (system is modified, replaced cheap fuse box with Blue Seas, battery behind panel)
