outboard1196
Hi all this is my first post , I've had my system running for about 6 months . I'm adding more panels just want to check make sure its OK .
I currently have a renology rover 30A with 12v system 200w panels.
Spec is 400w max for 12v and 95v PV input .
I'm wanting to go to 400w of panels .
Originally I was going to put them all in series since my run from panel to charger is kind of long about 50ft .
But doing the math for max panel voltage in cold weather I get a max of about 106v . so I should do two series in parallel to be safe ?
And each parallel string have a 5a? Fuse ? Panel has open current max of 5.2A short circuit 4.9A .
Thanks
Thanks
