Hey All!
So I've got a question about this new Pecron Power Station (E600LFP) that I've got. The Pecron has two solar input options as follows:
Solar Input #1: Voc 12V~18V / 100W Max / 7A Max
Solar Input #2: Voc 32V~95V / 400W Max / 15A Max
The portable solar panel I've already got is the Rockpals RP085 200W which is an 18V unit. The panel has a DC5521 plug attached, which would fit the Solar Input #1 option. However this would be over the 100W Max spec, so I'm assuming I shouldn't risk damaging the unit there.
The other option would be possibly getting an Anderson to MC-4 adapter, and then using the MC-4 -> GX16 adapter that came with the Pecron to plug into the second input. However, this would be 18V / 200W, which would likely not be a high enough voltage to get any power into the Pecron, correct?
Let me know if I'm thinking about this wrong, and/or if you have any advice for me! Product links are below if helpful, and thanks a lot.
https://www.pecron.com/products/pecron-e600lfp-1200w-portable-power-station-lifepo4
https://www.amazon.com/ROCKPALS-Portable-Kickstand-Foldable-Generator/dp/B0B877FKRX
