Hi,
I recently purchased a Pecron E600LFP power station. The spec on the website (https://www.pecron.com/products/pecron-e600lfp-1200w-portable-power-station-lifepo4) states: PV Input: 12~18V-100W(Max). 32~95V--400W(Max). It also states: PV input Voc 32V~95V / 400W Max / 15A Max
I have 2 290 wat solar panels (QSELLS Q.PEAK BLK-G4.1) whereas the Voc is 39.19 volts and the current Immp is 9.07 amps and the Isc is 9.63 amps.
I wanted to put these in series so that the voltage would be 80 volts and the Amps would be 9.07. Does this stay within the range of the MPPT of 15 amp of input. I am not sure if the 15 amps is the input allowed from the panels or the max amps of the MPPT whereas I would have to say that 2 x 290 watt panels is 580 watts and divide that by the 24 volt battery and wind up with 24 Amps which I am guessing would damage the MPPT
I appreciate your help.
