So I am new to this, and while I think I have the math down, I definitely would like a double check. I have 2 Deye 12k inverters (same as Sol-Ark 12k). I'm hooking up 40 panels.
Panels have the following characteristics.
Pmax = 435W
Vmp = 72.9V
Imp = 5.97 A
Voc = 85.6V
Isc = 6.43A
Each inverter has
MaxV = 500V
MinV = 100V
Each inverter has 2 MPPT's and the operating range for them are 125-425.
So my plan was to run 10 panels to each MPPT, which means 20 panels to each inverter. Those 10 panels would be 2 parallel series of 5, which would make max Voc about 428V, which is below my invert max V which should be OK.
If that seems to make sense, my next question is about the PV disconnects. I was thinking one disconnect for each MPPT, so was going to use four DC circuit breakers like this one (https://www.amazon.com/Miniature-Circuit-Isolator-Magnetic-Disconnect/dp/B0983ZB3VD?th=1 ). since ISC of the panels is 6.4A, and I'm running 2 parallel strings, Im guessing the max current is less than 13Amp, so the 16 Amp breaker should be sufficient?
Appreciate any comments or advice people can give me on this.
Pmax = 435W
Vmp = 72.9V
Imp = 5.97 A
Voc = 85.6V
Isc = 6.43A
Each inverter has
MaxV = 500V
MinV = 100V
