Hi - Anyone interested in reading about my conundrum and sharing your knowledge and two cents to help me make an informed decision?
I purchased 3x200w panels for a van conversion based on functional specs and size. In short, the company had the size listed incorrectly on their site. I like the specs, but cannot fit 3 panels on the roof rack as intended (I could fit 2).
Here's where you come in. Based on the specs you see, would you advise that I ...
the roof rack from another company but the VOC combined would be around the same (82-85v)
Specs for the Bluetti AC200max - power input: 900w max - Over-voltage protection: 145VDC - MPPT voltage range: 10-145VDC - Current: 15A - Max input current of solar charging: 15.2A ± 0.3A | Specs for the panels I purchased: - Maximum Power: 200 Watts - Maximum System Voltage: 600V - Open Circuit Voltage: 37.5V - Short Circuit Current: 5.6A - Maximum Power Voltage: 30.2V - Maximum Power Current: 6.6a | Specs for the panels I received: - Maximum Power: 200 Watts - Maximum System Voltage: 1000v - Open Circuit Voltage (Voc): 43.5V - Short Circuit Current (Isc): 5.56A - Maximum Power Voltage (Vmp): 37.9V - Maximum Power Current (Imp): 5.28a |
The panels I purchased were chosen specifically because the Voc (37.5v) is higher than any 200w panels I've seen listed on the traditional van conversion sites (generally around 27v). I was thinking more bang for the buck, so to speak. Plan was to wire them in series increasing the voltage to 112.5v.Here's where you come in. Based on the specs you see, would you advise that I ...
- ... keep 2 panels to wire in series (VOC = 87v)
- ... return all 3 panels and use another company to purchase the 3x200w panels that I thought I was getting (if they are available from another company).
- ... if the 3 I want aren't available, I could order 2 panels with specs like these (the Isc and Imp are very different from other panels I've seen and I don't know what that means):
- Maximum Power: 250 Watts
- Open Circuit Voltage (Voc): 27.28V
- Short Circuit Current (Isc): 11.09A
- Maximum Power Voltage (Vmp): 23.83V
- Maximum Power Current (Imp): 10.51a
I don't know enough about solar to understand all of the specs and choose the best option. Hope you can help! Thanks in advance.
