Solar panel advice
Nuii
Earth
Need advice on additional solar panels to be added to my existing setup.
Currently I got a 2 x Growatt SPF 5000 ES inverter and 10 x fivestar 650w sola panels and now looking to add 4+ more panels. Unfortunately I couldn't find the same solar panels, is mixing solar panels a good idea if the voltages and amps are more or less the same?
Below are the panel specs for standard test conditions. Not sure which brands are good.
Prices for the panels are more or less the same.
Fivestar Mono (What I have now)BYD 550 Mono Solar PanelJinko 550wSeraphim 560W monoSeraphim 555W Bifacial
Nominal Maximum power(PMax)650W550W550W560W555W (Front)
389W (Back)
Optimum Operating Voltage (Vmp)51.2V42.49V40.90V42.56V42.1V (Front)
42.34V (Back)
Optimum Operating current (Imp)12.69A12.94A13.45A13.16A13.12A (Front)
9.19A (Back)
Open circuit voltage (Voc)60.92V50.32V49.62V49.90V49.80V (Front)
49.78V (Back)(
Short circuit current (Isc)13.58A13.61A14.03A14.21A14.1A (front)
9.94A (Back)
Look at some 325W panels and see if you can’t 2S some to ‘match’ your 650’s more closely.
On the other hand, you could buy whatever you want along with an appropriate Epever or Victron or Ampinvt SCC and just plumb them in to the battery bank directly.
