Parallel stuff
wme
Class A RV. A 200ah 12v Lifepo4 will not fit. 2ea. 100ah 12v lifepo4 will fit.
The question, using (same make and date) batteries in parallel will the BMS's play well together?? If they do, will I end up with a 200AH discharge system
would be good to know the brand, not all batteries can be paralelled.
as to your second question, provided 1 is bms that can be paralelled : yes
as to your thnx...
this is not an on demand helpdesk, so never expect a direct answer to your question.
if that is what you want, buy battleborn
Asked a simple question, got a simple answer. Wasn't aware a thankyou was problematic.
