Hi there
Current set up
1 string of cells to one Growatt SPH5000 with 2 x Growatt 6.5Kwh batteries
another string of cells to another growatt SPH5000
Growatt tell me that the version of SPH5000 I have can't be paralleled.
What I want to end up with is each inverter with it's own battery - giving me 6Kw of discharge. But it I move one battery over I will end up with situation of one battery discharging to charge up the other and then vice versa.
Looking at the Growatt Modbus protocol I can see registers for min/max temp for battery charging. What I am considering is changing these values every hour or so on each inverter to flip-flop which battery can be charged. The other option is a register to enable/disable AC charging
Can anyone see any problems with this or have a better idea?
TFB
Current set up
TFB
