Hi all,
Just looking for some feedback on a planned system. I already have a 8.2kw E/W solar array with a 6kw Growatt SPH6000 installed along side x3 6.5kwh Growatt batteries totalling 19.5kwh. Systems works great and I monitor it via Solar Assistant.
The plan is to add another 3.4kw of panels on a vertical south facing wall. G99 all sorted, just not sure about the inverter.... My installer said I could have a simple string inverter added to the system and my hybrid will most likely charge the batteries from the two strings it has already and from have the newly installed 3rd string. The SPH6000 can discharge at a rate of 4kw from the batteries. Another option is to have another hybrid e.g. a 3kw Growatt and connect both inverters via Growatt's SEM (Smart Energy Monitoring), that would manage the 6kw limit set by DNO and it will also up my in-house discharge rate to 7kw (if I move a battery from the SPH6000 unto the SPH3000).
Has anyone used the Growatt SEM before? Thoughts on adding another hybrid inverter?
Would a simple string inverter be better?
If it where you, what would you do?
The aim is to have the highest in house discharge possible as we have most things electric e.g. car, shower, cooker. We also plan to export lots in the summer using Octopus Flux tariff.
Thanks in advance for the feedback
