2Big2B
Free Wheeler
My question is about Top Balancing logic.
If I simply take a set of LiFePo4 batteries, line them up and connect them in parallel for top balancing without connecting the plus and minus poles to a my variable 20v/10A bench power supply, will they equalize and balance all by themselves, or does there need to be a current flow between the poles?
Is this a stupid question? Intuitively I cannot understand how cells that do not have a current flowing from negative to positive terminals in some manner would interact with each other - just because all their poles are commonly connected together with nothing else attached. What would cause them to equalize without some external load or power applied to the combined poles?
I have already top balanced my 8 cells both independently and in parallel with my bench power supply to 3.65v on all cells. I am about ready to hook up my BMS and move forward. Do I actually need to remove the power supply and just leave them all connected to each other in parallel overnight before proceeding? Or is that some meaningless ritual?
I am presently doing a few experiments though with some initial confusing results. If I try testing for current between the first negative terminal and the last in my string of 8 cells set up for parallel top balancing I seem to be seeing a slight voltage difference on my Fluke meter - consistently. That seems to suggest an argument that I am wrong in my thinking. Energy appears to be transmitted between the cells somehow. But How? Why? Am I operating with some basic misconception with a blind spot in my logic? Is it me?
I have never heard any discussion in any videos about such a phenomenon. Yet talking to others I have been assured that this weird osmosis occurs and seems to be commonly accepted. Am I missing some basic logic here, or is there some general misconception that all you need to do is hook up the cells in parallel and leave them alone after having brought them all up to 3.65v ?
Looking at one discussion I find a couple of curious terms too (from Energy Storage/DYI LiFeP04 Battery Banks forum:
"PLAN A: 1. Parallel them and "balance" them au naturel overnight - not really balancing, just getting the voltages in the same ballpark."
And ... "active balancing " (i.e, with a BMS or Bench supply)
(Active vs Passive "au naturel overnight" Top Balancing) ? Really?
I am confused.
Or am I just having a senior moment?
"Top balancing, recommendations (fastest or best practices)"
I am confused.
