chrisstratton
- May 24, 2021
- 119
Thanks, everyone, for all the responses. Does anyone recommend a variable voltage charger??
I think I would need something to accumulate the hours consumedMy Pioneer 9K BTU mini-split draws 800 watts and it seems running continuously lately during the day in Florida heat, so it would deplete a Signature Solar (5Kwh) battery in approximately six hours. I use this clamp on meter (https://www.amazon.com/dp/B07Z398YWF?psc=1&ref=ppx_yo2ov_dt_b_product_details) to see how much AC current it draws by clamping it in the circuit breaker panel. You are showing that you got "1740w PV solar panels". That is the ideal case. It doesn't appear that you got enough solar to keep your air-condition unit, the ref., and charge the battery, and your 24V/150ah battery is not much.
Well actually, I mean watts which would mean measuring the current overtimeI think I would need something to accumulate the hours consumed
I hope I found a cause for this problem. It appears that the 63 amp double pole breaker has failed after about a year or a little less of use. I checked the voltage on the input side coming in from the solar panels and it reads correctly at 77 V. The output voltage, that is to say the protected side of the breaker, there’s only 11 or 12 V whether or not the breaker is closed or open. I have ordered another to try to resolve the problem. I have four sunpower 435 panels each offering about 6 A hooked in parallel. My math shows a potential of 24 A which should be well below the 63 A of the breaker rating. I thinking is that the breaker has been failing slowly over time giving only partial current
Is there a brand you like? Amazon wasn't calling them up directly for me.I don't trust no-name Chinese DC breakers. I only use reputable brands for protection devices.
Check the bottom left (black) leadI hope I found a cause for this problem. It appears that the 63 amp double pole breaker has failed after about a year or a little less of use. I checked the voltage on the input side coming in from the solar panels and it reads correctly at 77 V. The output voltage, that is to say the protected side of the breaker, there’s only 11 or 12 V whether or not the breaker is closed or open. I have ordered another to try to resolve the problem. I have four sunpower 435 panels each offering about 6 A hooked in parallel. My math shows a potential of 24 A which should be well below the 63 A of the breaker rating. I thinking is that the breaker has been failing slowly over time giving only partial current
Agree with the "getting hot" brown spot as indicating trouble. I did put a screw driver on that lead/connection and it didn't move. The fact that I don't seem to get ANY voltage across the breaker was enough (that and the brown spot) were enough for me to order a replacement. When I put that new one in, I'll definitely check the tightness as well as look for corrosion. I remain hopeful that poor conduction across that device and the potential for random "partial failures" is the root of my problem. I haven't had to reset the breaker, but I believe they can fail w/o tripping.I found one "not tight"
I'd also check to see if the lead went into the fitting (whatever it's called)When I put that new one in, I'll definitely check the tightness as well as look for corrosion.
Thanks!
