Hi all, newcomer here.
I've tried searching for the answer to my question but to no avail.
We have a recently installed 4.3kW solar system in Bristol in the UK. Faces South West (50 degrees past south) at a tilt of around 18 degrees).
I'm trying to understand if the system is getting the power output it should.
On a bright sunny day, the most power I've seen from the system is around 1.5kW. I'm obviously aware the sun's angle is lower at this time of year, but I would have expected more. Or am I being too optimistic?
On thick cloudy days, the power is often as low as 20W. Again I'd have expected more, even when under rainclouds.
Will the power really be significantly more in other months of the year, when the sun is higher? Can I expect the 1.5kW to jump up a lot as the seasons change?
I appreciate total energy output will be less in winter because of far fewer daylight hours, but when the sun is actually shining I'd have thought the power produced wouldn't be too different. Or does the angle of the sun really make that much difference?
Thanks in advance,
Gareth
Thanks in advance,
Gareth
