Street Vendor King
The mobile vending cart is parked overnight at home while being plugged into the grid, in the morning the vendors will unplug from the grid and start roaming the streets to make money.
Charge set up: Grid>Outlet on Cart (A)>Inverter Charger (B)>Battery (C)
Equipment Setup: Refrigerator/water pump/food warmer 600 simultaneous watt total>custom On/Off switch for each device(D)>Inverter Charger(B)>Battery (C)
Here is where I need help: what is the best equipment for my needs? The more compact the better. I have already found a couple items myself.
A | |
B | There are so many invertor chargers to choose from and many have way too many features that I dont need. A 1.5kw invertor max and 40-80Amp charger is adequate. |
C | |
D | What would be the best switch for each seperate equipment on off switch? |
