Hello everyone!
I have scoured the manual, this forum, as well as asked Signature Solar Tech support and I am still at a loss.
Background on my system:
- Two 6000XP in parallel supplying split phase.
- 4 48V EG4 Lifep04 batteries in parallel (20KWH) with bus bars.
- Battery share active and both inverters have 2/0 battery cables to the bus bars.
- Grid connection is 50A RV pedestal
Loads:
- 5th Wheel RV with 50A nema 15-50 hookup
(Full size fridge, microwave, electric fireplace, water heater etc...)
- Tesla model 3 with 240V charger
So here is my issue... The 6000xp is able to use 50A in bypass mode. I have two 6000xps in parallel, which would allow them to pull up to 100A combined. Unfortunately, I only have a 50A grid connection, which trips every time the bypass load is too high. Is there a way to limit the bypass current in each inverter? I would like to limit the bypass current for each to 25A so my 50A breaker stops tripping when loads are too high.
Thanks in advance!
Loads:
Thanks in advance!
