lacrimosa2k2
- Oct 30, 2021
- 6
Hello,
I wanted to introduce you to my little project, maybe it helps one or the other.
it is based on a esp8266 and a max3232
currently i am testing the software with an easun smv 3k plus, orginal a 3023MSXE with PI30 protokol.
actualy works to get the solar, battery and grid data
at the moment only reading is supported, but it is in progress to get an option for setting parameters
when it doenst work, pleas share me the log files from watchpower, the inverter has varius protocol versions.
for interesting users, it has an option for debug data (raw from inverter) to mqtt and serial log over the second serial port
GitHub - softwarecrash/Solar2MQTT: ESP8266 based WiFi and MQTT interface for MPPT Inverters that use watchpower
ESP8266 based WiFi and MQTT interface for MPPT Inverters that use watchpower - softwarecrash/Solar2MQTT
github.com
