MadMacks
Off Gridder
I recently got a call from a friend that was building a small 12v battery and was having issues with getting it to work. There were a variety of issues that I helped him fix, but I noticed that he’d purchased bolts for his cell bus bars and hadn’t used studs with nuts. The bolts he was using were around 1/2” long and I was concerned that he might have bottomed them out and punched thru the bottom of the threaded holes. The battery seems to be fine, but it does look like he may have done that in one or two of the cells.
So…question…assuming there may be cracked bottoms in some of the terminal post, what, if any, problems might that cause? If the post is filled with a proper bolt and tightened up would that reseal up the top of the cell? Or should the cells be replaced if they are in tact punched thru? I’ve never seen a discussion about this so I thought I’d ask…
